REST API reference
Restore keys for an SVM from a configured AKV
Restores the keys for a Storage Virtual Machine (SVM) from a configured Azure Key Vault (AKV). This operation is specific to the Azure NetApp Files Cloud Volume Services, typically used to manage encryption keys securely.
HTTP method and endpoint
POST /security/azure-key-vaults/{azure_key_vault.uuid}/restore
Introduced in
ONTAP 9.8
Usage notes
Restore the keys for an SVM from a configured AKV. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
  • security key-manager external azure restore
string
path
True
UUID of the existing AKV configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537120
Azure Key Vault is not configured for the given SVM.
65537515
Failed to restore keys on some nodes in the cluster.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
