Restore keys for an SVM from a configured AKV
Restores the keys for a Storage Virtual Machine (SVM) from a configured Azure Key Vault (AKV). This operation is typically performed when you need to recover or re-establish secure access to your SVM.
HTTP method and endpoint
POST /security/azure-key-vaults/{uuid}/restore
Introduced in
ONTAP 9.10
Usage notes
Restore the keys for an SVM from a configured AKV.
Related ONTAP commands
security key-manager external azure restore
uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537120 |
Azure Key Vault is not configured for the given SVM. |
65537515 |
Failed to restore keys on some nodes in the cluster. |
65537544 |
Missing wrapped top-level internal key protection key (KEK) from internal database. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
