REST API reference
Delete a Vscan configuration
DELETE /protocols/vscan/{svm.uuid}
Introduced In: 9.6
Deletes a Vscan configuration.
Important notes:
  • The Vscan DELETE endpoint deletes all of the Vscan configuration of an SVM. It first disables the Vscan and then deletes all of the SVM scanner-pools, On-Access policies, and On-Demand policies.
  • Disable the active Vscan On-Access policy on an SVM before performing the Vscan delete operation on that SVM.
  • vserver vscan scanner-pool delete
  • vserver vscan on-access-policy delete
  • vserver vscan on-demand-policy delete
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027259
A scanner-pool, an On-Access policy, or an On-Demand policy might fail to get deleted due to either a systematic error or some hardware failure. The error code returned details the failure along with the reason for the failure. For example, "Failed to delete On-Access policy "sp1". Reason: "Failed to delete policy. Reason: policy must be disabled before being deleted.". Retry the operation."
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
