Delete a Vscan configuration
Deletes a Vscan configuration to remove all associated settings from an SVM, including disabling Vscan and deleting scanner pools and policies. This is typically done when you no longer need virus scanning capabilities on the SVM.
HTTP method and endpoint
DELETE /protocols/vscan/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Important notes:
The Vscan DELETE endpoint deletes all of the Vscan configuration of an SVM. It first disables the Vscan and then deletes all of the SVM scanner-pools, On-Access policies, and On-Demand policies.
Disable the active Vscan On-Access policy on an SVM before performing the Vscan delete operation on that SVM.
Related ONTAP commands
vserver vscan scanner-pool delete -
vserver vscan on-access-policy delete -
vserver vscan on-demand-policy delete
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027259 |
A scanner-pool, an On-Access policy, or an On-Demand policy might fail to get deleted due to either a systematic error or some hardware failure. The error code returned details the failure along with the reason for the failure. For example, "Failed to delete On-Access policy "sp1". Reason: "Failed to delete policy. Reason: policy must be disabled before being deleted.". Retry the operation." |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
