Delete a Vscan configuration
DELETE /protocols/vscan/{svm.uuid}
Introduced In: 9.6
Deletes a Vscan configuration.
Important notes:
The Vscan DELETE endpoint deletes all of the Vscan configuration of an SVM. It first disables the Vscan and then deletes all of the SVM scanner-pools, On-Access policies, and On-Demand policies.
Disable the active Vscan On-Access policy on an SVM before performing the Vscan delete operation on that SVM.
Related ONTAP commands
vserver vscan scanner-pool delete -
vserver vscan on-access-policy delete -
vserver vscan on-demand-policy delete
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027259  |
A scanner-pool, an On-Access policy, or an On-Demand policy might fail to get deleted due to either a systematic error or some hardware failure. The error code returned details the failure along with the reason for the failure. For example, "Failed to delete On-Access policy "sp1". Reason: "Failed to delete policy. Reason: policy must be disabled before being deleted.". Retry the operation."  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
