REST API reference
Retrieve the NDMP node configuration for a node
Retrieves the NDMP node configuration for a specific node to view or manage its NDMP settings.
HTTP method and endpoint
GET /protocols/ndmp/nodes/{node.uuid}
Introduced in
ONTAP 9.7
  • system services ndmp show
node.uuid
string
path
True
Node UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_types
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled?
node
node
Storage system node
user
string
NDMP user ID
      "href": "/api/resourcelink"
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "node": {
    "name": "node1",
  "user": "ndmp_user"
Status: Default
ONTAP Error Response codes
Error code Description
68812801
Node-scoped operations are not allowed in an SVM-scope.
68812802
The UUID is not valid.
68812804
Failed to get the node name from the specified node UUID.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
Storage system node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
