Retrieve the NDMP node configuration for a node
GET /protocols/ndmp/nodes/{node.uuid}
Introduced In: 9.7
Retrieves an NDMP node configuration for a specific node.
Related ONTAP commands
system services ndmp show
Learn more
node.uuid  |
string  |
path  |
True  |
Node UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
authentication_types  |
array[string]  |
NDMP authentication types.  |
enabled  |
boolean  |
Is the NDMP service enabled?  |
node  |
Storage system node  |
user  |
string  |
NDMP user ID  |
      "href": "/api/resourcelink"
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "node": {
    "name": "node1",
  "user": "ndmp_user"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812801  |
Node-scoped operations are not allowed in an SVM-scope.  |
68812802  |
The UUID is not valid.  |
68812804  |
Failed to get the node name from the specified node UUID.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
node
Storage system node
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
