REST API reference
Retrieve NFS client information
Retrieves information about NFS clients to understand their configurations and interactions with the storage system. This helps you manage and optimize NFS client connections effectively.
HTTP method and endpoint
GET /protocols/nfs/connected-client-maps
Introduced in
ONTAP 9.11
Usage notes
Retrieves NFS clients information.
client_ips
string
query
False
Filter by client_ips
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
server_ip
string
query
False
Filter by server_ip
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[nfs_clients_map]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_ips": [
        "127.0.0.1"
      "node": {
        "name": "node1",
      "server_ip": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
nfs_clients_map
_links
_links
client_ips
array[string]
Specifies the IP address of the client.
node
node
server_ip
string
Specifies the IP address of the server.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
