Retrieve NFS client information
Retrieves information about NFS clients, helping you understand their configuration and status.
HTTP method and endpoint
GET /protocols/nfs/connected-client-maps
Introduced in
ONTAP 9.11
Usage notes
Retrieves NFS clients information.
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
client_ips |
string |
query |
False |
Filter by client_ips |
server_ip |
string |
query |
False |
Filter by server_ip |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[nfs_clients_map] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"client_ips": [
"127.0.0.1"
"node": {
"name": "node1",
"server_ip": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
nfs_clients_map
_links |
client_ips |
array[string] |
Specifies the IP address of the client. |
node |
server_ip |
string |
Specifies the IP address of the server. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
