REST API reference
Retrieve NFS client information
GET /protocols/nfs/connected-client-maps
Introduced In: 9.11
Retrieves NFS clients information.
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
client_ips
string
query
False
Filter by client_ips
server_ip
string
query
False
Filter by server_ip
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[nfs_clients_map]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_ips": [
        "127.0.0.1"
      "node": {
        "name": "node1",
      "server_ip": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
nfs_clients_map
_links
_links
client_ips
array[string]
Specifies the IP address of the client.
node
node
server_ip
string
Specifies the IP address of the server.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
