Retrieve an NVMe subsystem controller
GET /protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
Introduced In: 9.6
Retrieves an NVMe subsystem controller.
Related ONTAP commands
vserver nvme subsystem controller show
Learn more
Name | Type | In | Required | Description |
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
id |
string |
path |
True |
The unique identifier of the NVMe subsystem controller. |
fields |
array[string] |
query |
False |
Status: 200, Ok
Name | Type | Description |
_links |
admin_queue |
dh_hmac_chap |
A container for properties of the NVMe in-band authentication DH-HMAC-CHAP protocol used by the the host connection to the controller. |
digest |
Digests are properties of NVMe controllers created over the NVMe/TCP transport protocol. The usage of digests is negotiated between the host and the controller during connection setup. ONTAP enables digests only if the host requests them. The header digest is the crc32 checksum of the header portion of the NVMe/TCP PDU. The data digest is the crc32 checksum of the data portion of the NVMe/TCP PDU. If a digest is enabled, upon receiving an NVMe/TCP PDU, ONTAP calculates the crc32 checksum of the associated portion of the PDU and compares it with the digest value present in the transmitted PDU. If there is a mismatch, ONTAP returns an error and destroys the controller.
host |
Properties of the connected host. |
id |
string |
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'. |
interface |
The logical interface through which the host is connected. |
io_queue |
Properties of the I/O queues available to the controller. |
keep_alive_timeout |
integer |
The keep-alive timeout value for the controller and all of its host connections, in milliseconds. If the NVMe controller does not receive a keep-alive request or an I/O request within the timeout window, the NVMe controller terminates its admin queue and I/O queue connections leading to NVMe controller teardown. If the NVMe host does not receive a response to a keep-alive request or an I/O request within the timeout window, the NVMe host initiates a connection disconnect. |
node |
subsystem |
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts. |
svm |
tls |
A container for properties that describe the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. |
transport_protocol |
string |
Transport Protocol |
"href": "/api/resourcelink"
"admin_queue": {
"depth": 0
"dh_hmac_chap": {
"group_size": "string",
"hash_function": "string",
"mode": "bidirectional"
"host": {
"id": "b8546ca6097349e5b1558dc154fc073b",
"nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
"transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
"id": "0040h",
"interface": {
"name": "lif1",
"transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
"uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
"io_queue": {
"count": 0,
"depth": [
"integer"
"keep_alive_timeout": 1500,
"node": {
"name": "node1",
"subsystem": {
"name": "subsystem1",
"svm": {
"name": "svm1",
"tls": {
"cipher": "tls_aes_128_gcm_sha256",
"key_type": "configured",
"psk_identity": "NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:713b3816-f9bf-ba43-b95a-5e4bf8c726e9 nqn.1992-08.com.netapp:sn.76f9d9bfb96511eea95e005056bb72b2:subsystem.ss1 mS1A7nrooevA9ZqAM09fQzWQlB2UZRt0BE1X4vINjY0=:"
"transport_protocol": "string"
Status: Default
ONTAP Error Response Codes
Error Code | Description |
72090001 |
The supplied subsystem identifier does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
admin_queue
depth |
integer |
The depth of the admin queue for the controller. |
dh_hmac_chap
group_size |
string |
The Diffie-Hellman group size used for NVMe in-band authentication. This property is populated only when NVMe in-band authentication was performed for the NVMe-oF transport connection. |
hash_function |
string |
The hash function used for NVMe in-band authentication. This property is populated only when NVMe in-band authentication was performed for the NVMe-oF transport connection. |
mode |
string |
The NVMe in-band authentication mode used for the host connection. When set to:
digest
data |
boolean |
Reports if digests are enabled for the data portion of the PDU. |
header |
boolean |
Reports if digests are enabled for the header portion of the PDU. |
host
id |
string |
The host identifier registered with the controller. |
nqn |
string |
The NVMe qualified name of the host. |
transport_address |
string |
The transport address of the host. |
interface
name |
string |
The name of the logical interface. |
transport_address |
string |
The transport address of the logical interface. |
uuid |
string |
The unique identifier of the logical interface. |
io_queue
count |
integer |
The number of I/O queues available to the controller. |
depth |
array[integer] |
The depths of the I/O queues. |
node
_links |
name |
string |
uuid |
string |
subsystem
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
tls
cipher |
string |
The cipher suite used for the transport by the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. This property is populated only when encryption is in use for the transport connection. |
key_type |
string |
The method by which the TLS pre-shared key (PSK) was obtained when establishing the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. Possible values:
psk_identity |
string |
The TLS PSK identity supplied by the host when establishing the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. This property is populated only when encryption is in use for the transport connection. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
