REST API reference
Retrieve an NVMe subsystem controller
Obtains details about an NVMe subsystem controller, which helps you understand its configuration and status in your environment.
HTTP method and endpoint
GET /protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem controller.
  • vserver nvme subsystem controller show
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
id
string
path
True
The unique identifier of the NVMe subsystem controller.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
admin_queue
admin_queue
dh_hmac_chap
dh_hmac_chap
A container for properties of the NVMe in-band authentication DH-HMAC-CHAP protocol used by the the host connection to the controller.
host
host
Properties of the connected host.
id
string
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'.
interface
interface
The logical interface through which the host is connected.
io_queue
io_queue
Properties of the I/O queues available to the controller.
keep_alive_timeout
integer
The keep-alive timeout value for the controller and all of its host connections, in milliseconds.
If the NVMe controller does not receive a keep-alive request or an I/O request within the timeout window, the NVMe controller terminates its admin queue and I/O queue connections leading to NVMe controller teardown. If the NVMe host does not receive a response to a keep-alive request or an I/O request within the timeout window, the NVMe host initiates a connection disconnect.
node
node
subsystem
subsystem
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
svm
svm
      "href": "/api/resourcelink"
  "admin_queue": {
    "depth": 0
  "dh_hmac_chap": {
    "group_size": "string",
    "hash_function": "string",
    "mode": "bidirectional"
  "host": {
    "id": "b8546ca6097349e5b1558dc154fc073b",
    "nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
    "transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
  "id": "0040h",
  "interface": {
    "name": "lif1",
    "transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
    "uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
  "io_queue": {
    "count": 0,
    "depth": [
      "integer"
  "keep_alive_timeout": 1500,
  "node": {
    "name": "node1",
  "subsystem": {
    "name": "subsystem1",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The supplied subsystem identifier does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
admin_queue
depth
integer
The depth of the admin queue for the controller.
dh_hmac_chap
group_size
string
The Diffie-Hellman group size used for NVMe in-band authentication.
hash_function
string
The hash function used for NVMe in-band authentication.
mode
string
The NVMe in-band authentication mode used for the host connection. When set to:
  • none: Neither the host nor controller was authenticated.
  • unidirectional: The controller authenticated the host.
  • bidirectional: The controller authenticated the host and the host authenticated the controller.
host
id
string
The host identifier registered with the controller.
nqn
string
The NVMe qualified name of the host.
transport_address
string
The transport address of the host.
interface
name
string
The name of the logical interface.
transport_address
string
The transport address of the logical interface.
uuid
string
The unique identifier of the logical interface.
io_queue
count
integer
The number of I/O queues available to the controller.
depth
array[integer]
The depths of the I/O queues.
node
_links
_links
name
string
uuid
string
subsystem
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
