REST API reference
Retrieve an NVMe subsystem controller
Obtains details about an NVMe subsystem controller, which helps you understand its configuration and status in your environment.
HTTP method and endpoint
GET /protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem controller.
  • vserver nvme subsystem controller show
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
id
string
path
True
The unique identifier of the NVMe subsystem controller.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
admin_queue
admin_queue
dh_hmac_chap
dh_hmac_chap
A container for properties of the NVMe in-band authentication DH-HMAC-CHAP protocol used by the the host connection to the controller.
digest
digest
Digests are properties of NVMe controllers created over the NVMe/TCP transport protocol. The usage of digests is negotiated between the host and the controller during connection setup. ONTAP enables digests only if the host requests them. The header digest is the crc32 checksum of the header portion of the NVMe/TCP PDU. The data digest is the crc32 checksum of the data portion of the NVMe/TCP PDU.
If a digest is enabled, upon receiving an NVMe/TCP PDU, ONTAP calculates the crc32 checksum of the associated portion of the PDU and compares it with the digest value present in the transmitted PDU. If there is a mismatch, ONTAP returns an error and destroys the controller.
  • readOnly: 1
  • Introduced in: 9.15
host
host
Properties of the connected host.
id
string
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'.
interface
interface
The logical interface through which the host is connected.
io_queue
io_queue
Properties of the I/O queues available to the controller.
keep_alive_timeout
integer
The keep-alive timeout value for the controller and all of its host connections, in milliseconds.
If the NVMe controller does not receive a keep-alive request or an I/O request within the timeout window, the NVMe controller terminates its admin queue and I/O queue connections leading to NVMe controller teardown. If the NVMe host does not receive a response to a keep-alive request or an I/O request within the timeout window, the NVMe host initiates a connection disconnect.
node
node
subsystem
subsystem
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
svm
svm
tls
tls
A container for properties that describe the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem.
transport_protocol
string
Transport Protocol
      "href": "/api/resourcelink"
  "admin_queue": {
    "depth": 0
  "dh_hmac_chap": {
    "group_size": "string",
    "hash_function": "string",
    "mode": "bidirectional"
  "host": {
    "id": "b8546ca6097349e5b1558dc154fc073b",
    "nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
    "transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
  "id": "0040h",
  "interface": {
    "name": "lif1",
    "transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
    "uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
  "io_queue": {
    "count": 0,
    "depth": [
      "integer"
  "keep_alive_timeout": 1500,
  "node": {
    "name": "node1",
  "subsystem": {
    "name": "subsystem1",
  "svm": {
    "name": "svm1",
  "tls": {
    "cipher": "tls_aes_128_gcm_sha256",
    "key_type": "configured",
    "psk_identity": "NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:713b3816-f9bf-ba43-b95a-5e4bf8c726e9 nqn.1992-08.com.netapp:sn.76f9d9bfb96511eea95e005056bb72b2:subsystem.ss1 mS1A7nrooevA9ZqAM09fQzWQlB2UZRt0BE1X4vINjY0=:"
  "transport_protocol": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The supplied subsystem identifier does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
admin_queue
depth
integer
The depth of the admin queue for the controller.
dh_hmac_chap
group_size
string
The Diffie-Hellman group size used for NVMe in-band authentication. This property is populated only when NVMe in-band authentication was performed for the NVMe-oF transport connection.
hash_function
string
The hash function used for NVMe in-band authentication. This property is populated only when NVMe in-band authentication was performed for the NVMe-oF transport connection.
mode
string
The NVMe in-band authentication mode used for the host connection. When set to:
  • none: Neither the host nor controller was authenticated.
  • unidirectional: The controller authenticated the host.
  • bidirectional: The controller authenticated the host and the host authenticated the controller.
digest
data
boolean
Reports if digests are enabled for the data portion of the PDU.
header
boolean
Reports if digests are enabled for the header portion of the PDU.
host
id
string
The host identifier registered with the controller.
nqn
string
The NVMe qualified name of the host.
transport_address
string
The transport address of the host.
interface
name
string
The name of the logical interface.
transport_address
string
The transport address of the logical interface.
uuid
string
The unique identifier of the logical interface.
io_queue
count
integer
The number of I/O queues available to the controller.
depth
array[integer]
The depths of the I/O queues.
node
_links
_links
name
string
uuid
string
subsystem
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
svm
_links
_links
name
string
uuid
string
tls
cipher
string
The cipher suite used for the transport by the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. This property is populated only when encryption is in use for the transport connection.
key_type
string
The method by which the TLS pre-shared key (PSK) was obtained when establishing the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. Possible values:
  • none - TLS encryption is not configured for the host connection.
  • configured - A user supplied PSK was used for the encrypted NVMe/TCP-TLS transport connection between the host and the NVMe subsystem.
  • generated - A PSK generated via NVMe in-band authentication was used to setup the encrypted NVMe/TCP-TLS transport connection between the host and the NVMe subsystem.
psk_identity
string
The TLS PSK identity supplied by the host when establishing the encrypted NVMe/TCP transport connection between the host and the NVMe subsystem. This property is populated only when encryption is in use for the transport connection.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
