Retrieve an NVMe subsystem controller
GET /protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
Retrieves an NVMe subsystem controller.
Related ONTAP commands
vserver nvme subsystem controller show
Learn more
subsystem.uuid  |
string  |
path  |
True  |
The unique identifier of the NVMe subsystem.  |
id  |
string  |
path  |
True  |
The unique identifier of the NVMe subsystem controller.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
admin_queue  |
host  |
Properties of the connected host.  |
id  |
string  |
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'.  |
interface  |
The logical interface through which the host is connected.  |
io_queue  |
Properties of the I/O queues available to the controller.  |
node  |
subsystem  |
svm  |
      "href": "/api/resourcelink"
  "admin_queue": {
    "depth": 0
  "host": {
    "id": "b8546ca6097349e5b1558dc154fc073b",
    "nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
    "transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
  "id": "0040h",
  "interface": {
    "name": "lif1",
    "transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
    "uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
  "io_queue": {
    "count": 0,
    "depth": [
      "integer"
  "node": {
    "name": "node1",
  "subsystem": {
    "name": "string",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001  |
The supplied subsystem identifier does not exist.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
admin_queue
depth  |
integer  |
The depth of the admin queue for the controller.  |
host
id  |
string  |
The host identifier registered with the controller.  |
nqn  |
string  |
The NVMe qualified name of the host.  |
transport_address  |
string  |
The transport address of the host.  |
interface
name  |
string  |
The name of the logical interface.  |
transport_address  |
string  |
The transport address of the logical interface.  |
uuid  |
string  |
The unique identifier of the logical interface.  |
io_queue
count  |
integer  |
The number of I/O queues available to the controller.  |
depth  |
array[integer]  |
The depths of the I/O queues.  |
node
_links  |
name  |
string  |
uuid  |
string  |
subsystem
_links  |
name  |
string  |
The name of the NVMe subsystem.  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
