Retrieve an NVMe subsystem controller
GET /protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
Retrieves an NVMe subsystem controller.
Related ONTAP commands
vserver nvme subsystem controller show
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
id |
string |
path |
True |
The unique identifier of the NVMe subsystem controller. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
admin_queue |
host |
Properties of the connected host. |
id |
string |
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'. |
interface |
The logical interface through which the host is connected. |
io_queue |
Properties of the I/O queues available to the controller. |
node |
subsystem |
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts. |
svm |
"href": "/api/resourcelink"
"admin_queue": {
"depth": 0
"host": {
"id": "b8546ca6097349e5b1558dc154fc073b",
"nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
"transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
"id": "0040h",
"interface": {
"name": "lif1",
"transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
"uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
"io_queue": {
"count": 0,
"depth": [
"integer"
"node": {
"name": "node1",
"subsystem": {
"name": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The supplied subsystem identifier does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
admin_queue
depth |
integer |
The depth of the admin queue for the controller. |
host
id |
string |
The host identifier registered with the controller. |
nqn |
string |
The NVMe qualified name of the host. |
transport_address |
string |
The transport address of the host. |
interface
name |
string |
The name of the logical interface. |
transport_address |
string |
The transport address of the logical interface. |
uuid |
string |
The unique identifier of the logical interface. |
io_queue
count |
integer |
The number of I/O queues available to the controller. |
depth |
array[integer] |
The depths of the I/O queues. |
node
_links |
name |
string |
uuid |
string |
subsystem
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
