REST API reference
Retrieve a group entry
GET /security/groups/{owner.uuid}/{name}/{type}
Introduced In: 9.16
Retrieves a group entry.
  • security login group show
owner.uuid
string
path
True
Group owner. Used to identify a cluster or an SVM.
name
string
path
True
Group name.
type
string
path
True
Group type.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
comment
string
Any comment regarding this group entry.
create_time
string
Date and time indicating when this group entry was created.
id
integer
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number.
name
string
Group name.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
type
string
Group type.
uuid
string
Group UUID from external Active Directory.
      "href": "/api/resourcelink"
  "comment": "Azure Group",
  "create_time": "string",
  "id": 0,
  "name": "AzureGroup1",
  "owner": {
    "name": "svm1",
  "scope": "string",
  "type": "entra",
  "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
owner
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
