Retrieve a group entry
GET /security/groups/{owner.uuid}/{name}/{type}
Introduced In: 9.16
Retrieves a group entry.
Related ONTAP commands
security login group show
owner.uuid |
string |
path |
True |
Group owner. Used to identify a cluster or an SVM. |
name |
string |
path |
True |
Group name. |
type |
string |
path |
True |
Group type. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Any comment regarding this group entry. |
create_time |
string |
Date and time indicating when this group entry was created. |
id |
integer |
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number. |
name |
string |
Group name. |
owner |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
type |
string |
Group type. |
uuid |
string |
Group UUID from external Active Directory. |
"href": "/api/resourcelink"
"comment": "Azure Group",
"create_time": "string",
"id": 0,
"name": "AzureGroup1",
"owner": {
"name": "svm1",
"scope": "string",
"type": "entra",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
owner
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
