REST API reference
Retrieve a WebAuthn credentials entry
GET /security/webauthn/credentials/{owner.uuid}/{username}/{index}/{relying_party.id}
Introduced In: 9.16
Retrieves a WebAuthn credentials entry.
  • security webauthn credentials show
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
username
string
path
True
Username.
index
integer
path
True
Index.
relying_party.id
string
path
True
Relying Party ID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
creation_time
string
Date and time indicating when this entry was created.
credential
credential
display_name
string
Display name.
index
integer
Index.
last_used_time
string
Date and time indicating when this entry was last used.
owner
svm_reference
public_key
public_key
relying_party
relying_party
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
username
string
Username.
      "href": "/api/resourcelink"
  "creation_time": "2024-08-05 22:38:55 -0400",
  "credential": {
    "id_sha": "xxxxxxxxxxxxxxxxxxxxxxebfb30f20bf6db74xxxxxxxxxxxxxxxxxxxxxxxxxx",
    "type": "string"
  "display_name": "admin",
  "index": 0,
  "last_used_time": "2024-08-05 22:48:55 -0400",
  "owner": {
    "name": "svm1",
  "public_key": {
    "algorithm": "ES-256",
    "value": "xxxxxxxxxxxxxxxxxxxxxe5sZohRRv2B10JjjALXmGRmEfFIxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxYr2+w=="
  "relying_party": {
    "id": "example.com",
    "name": "example.com"
  "scope": "string",
  "username": "admin"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
credential
id_sha
string
SHA-256 Hashed representation of Credential ID.
type
string
Credential type.
self
svm_reference
_links
_links
name
string
uuid
string
public_key
algorithm
string
Public key algorithm.
value
string
Public key value.
relying_party
id
string
Relying Party ID.
name
string
Relying Party Name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
