Retrieve a WebAuthn credentials entry
Retrieves a WebAuthn credentials entry to access and manage authentication configurations used for verifying user identities. This helps in maintaining secure access control within your environment.
HTTP method and endpoint
GET /security/webauthn/credentials/{owner.uuid}/{username}/{index}/{relying_party.id}
Introduced in
ONTAP 9.16
Related ONTAP commands
security webauthn credentials show
owner.uuid |
string |
path |
True |
Used to identify a cluster or an SVM. |
username |
string |
path |
True |
Username. |
index |
integer |
path |
True |
Index. |
relying_party.id |
string |
path |
True |
Relying Party ID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
creation_time |
string |
Date and time indicating when this entry was created. |
credential |
display_name |
string |
Display name. |
index |
integer |
Index. |
last_used_time |
string |
Date and time indicating when this entry was last used. |
owner |
public_key |
relying_party |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
username |
string |
Username. |
"href": "/api/resourcelink"
"creation_time": "2024-08-05 22:38:55 -0400",
"credential": {
"id_sha": "xxxxxxxxxxxxxxxxxxxxxxebfb30f20bf6db74xxxxxxxxxxxxxxxxxxxxxxxxxx",
"type": "string"
"display_name": "admin",
"index": 0,
"last_used_time": "2024-08-05 22:48:55 -0400",
"owner": {
"name": "svm1",
"public_key": {
"algorithm": "ES-256",
"value": "xxxxxxxxxxxxxxxxxxxxxe5sZohRRv2B10JjjALXmGRmEfFIxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxYr2+w=="
"relying_party": {
"id": "example.com",
"name": "example.com"
"scope": "string",
"username": "admin"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
credential
id_sha |
string |
SHA-256 Hashed representation of Credential ID. |
type |
string |
Credential type. |
_links
self |
svm_reference
_links |
name |
string |
uuid |
string |
public_key
algorithm |
string |
Public key algorithm. |
value |
string |
Public key value. |
relying_party
id |
string |
Relying Party ID. |
name |
string |
Relying Party Name. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
