Retrieve all WebAuthn supported algorithms entries
GET /security/webauthn/supported-algorithms
Introduced In: 9.16
Retrieve all WebAuthn supported algorithms entries.
Related ONTAP commands
security webauthn supported-algorithms show
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records.  |
records  |
array[supported_algorithms]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "algorithm": {
        "id": -7,
        "name": "ES-256",
        "type": "string"
      "owner": {
        "name": "svm1",
      "scope": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
collection_links
next  |
self  |
self_link
self  |
algorithm
id  |
integer  |
Algorithm ID.  |
name  |
string  |
Algorithm name.  |
type  |
string  |
Algorithm type.  |
_links
self  |
svm_reference
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
WebAuthn supported algorithms.
_links  |
algorithm  |
owner  |
SVM, applies only to SVM-scoped objects.  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
