REST API reference
Retrieve all WebAuthn supported algorithms entries
GET /security/webauthn/supported-algorithms
Introduced In: 9.16
Retrieve all WebAuthn supported algorithms entries.
  • security webauthn supported-algorithms show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[supported_algorithms]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "algorithm": {
        "id": -7,
        "name": "ES-256",
        "type": "string"
      "owner": {
        "name": "svm1",
      "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
algorithm
id
integer
Algorithm ID.
name
string
Algorithm name.
type
string
Algorithm type.
self
svm_reference
_links
_links
name
string
uuid
string
WebAuthn supported algorithms.
_links
self_link
algorithm
algorithm
owner
svm_reference
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
