REST API reference
Retrieve all WebAuthn supported algorithms entries
Accesses the list of WebAuthn supported algorithms, which helps you identify the available authentication methods for enhanced security configurations.
HTTP method and endpoint
GET /security/webauthn/supported-algorithms
Introduced in
ONTAP 9.16
Usage notes
Retrieve all WebAuthn supported algorithms entries.
  • security webauthn supported-algorithms show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[supported_algorithms]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "algorithm": {
        "id": -7,
        "name": "ES-256",
        "type": "string"
      "owner": {
        "name": "svm1",
      "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
algorithm
id
integer
Algorithm ID.
name
string
Algorithm name.
type
string
Algorithm type.
self
svm_reference
_links
_links
name
string
uuid
string
WebAuthn supported algorithms.
_links
self_link
algorithm
algorithm
owner
svm_reference
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
