REST API reference
Update an initiator group
Updates an initiator group to modify its configuration settings or properties according to your requirements. This is useful for managing access controls and permissions in your storage environment.
HTTP method and endpoint
PATCH /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
  • lun igroup modify
  • lun igroup rename
  • lun igroup bind
  • lun igroup unbind
uuid
string
path
True
The unique identifier of the initiator group.
Request Body
Name Type Description
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
connectivity_tracking
An overview of the connections to ONTAP by the initiators in this group.
  • readOnly: 1
  • Introduced in: 9.11
delete_on_unmap
boolean
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created.
lun_maps
array[lun_maps]
All LUN maps with which the initiator is associated.
If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved.
There is an added computational cost to retrieving property values for lun_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
parent_igroups
array[igroup_parent]
The initiator groups that contain this initiator group as a member.
portset
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
In a nested initiator group hierarchy, only a portset bound to the initiator group at the same level at which it is mapped, applies; portsets bound to parent or child initiator groups are ignored.
Optional in POST and PATCH. To unbind a portset from the initiator group, PATCH the portset object to null, or PATCH portset.name to an empty string ("").
replication
replication
Properties related to initiator group replication.
supports_igroups
boolean
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The initiators.name property cannot be used to determine this via a query because it reports initiators inherited from nested igroups.
target
target
Properties of the SCSI target to which the initiator group provides access.
uuid
string
Example request
  "comment": "string",
  "connectivity_tracking": {
    "alerts": [
    "connection_state": "string",
    "required_nodes": [
        "name": "node1",
  "lun_maps": [
      "logical_unit_number": 0,
      "lun": {
        "name": "lun1",
        "node": {
          "name": "node1",
  "name": "igroup1",
  "os_type": "string",
  "parent_igroups": [
      "name": "igroup1",
      "parent_igroups": [
        null
  "portset": {
    "name": "portset1",
  "replication": {
    "error": {
      "igroup": {
        "name": "igroup1",
    "peer_svm": {
      "name": "peer1",
      "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
    "state": "string"
  "target": {
    "firmware_revision": "9111",
    "product_id": "LUN C-Mode",
    "vendor_id": "NETAPP"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254264
An attempt was made to bind a portset to an initiator group that is already bound to a portset.
5373958
An invalid initiator group name was supplied for a rename operation.
5374023
A rename operation failed because an initiator group with the same name already exists.
5374027
An attempt was made to bind a portset with no member network interfaces to the initiator group.
5374028
An attempt was made to bind a portset with an incompatible protocol to the initiator group.
5374733
An initiator is already in another initiator group with a conflicting operating system type.
5374745
An attempt was made to add an initiator group as a child to itself.
5374746
The cluster is currently running in a mixed version and nested initiator groups cannot be created until the effective cluster version reaches 9.9.1.
5374747
The cluster is currently running in a mixed version and initiator group comments cannot be created until the effective cluster version reaches 9.9.1.
5374749
An initiator group's replication peer SVM cannot be changed without first being cleared.
5374759
An error was reported by the peer cluster while modifying a replicated initiator group. The specific error will be included as a nested error.
5374763
An error was reported by the peer cluster while renaming a replicated initiator group. The specific error will be included as a nested error.
5374765
An initiator group cannot be replicated if it has unreplicated child initiator groups.
5374766
A replicated initiator group cannot be changed to unreplicated if it is the child of a replicated initiator group.
5374770
An unreplicated initiator group cannot be changed to replicated due to a conflict in its LUN maps.
5374852
The initiator group does not exist.
5374868
The initiator group was partially modified before an error was encountered while renaming the initiator group.
5375258
The igroup is already replicated to a different peer SVM.
5376253
Initiator group replication requires an effective cluster version of 9.15.1.
5376255
Initiator group replication requires the peer cluster to have an effective cluster version of 9.15.1.
5376488
An NVMe over Fabrics subsystem already exists with the requested name.
6620376
SVM peering information is unavailable.
6620384
The supplied SVMs are not peered.
string
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state of the initiator group.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
alerts
required_nodes
name
string
uuid
string
alerts
array[alerts]
connection_state
string
Connection state.
required_nodes
array[required_nodes]
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes.
igroup_child
comment
string
igroups
array[igroup_child]
Further nested initiator groups.
A link to the initiator with connectivity information relevant to its membership of this initiator group.
string
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
string
Overview of the initiator's connections to ONTAP.
connection_state
string
Connection state.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
name
string
uuid
string
peer_svms
A reference to an SVM peer relationship.
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET.
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm
boolean
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the proximity sub-object.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the initiator is proximal.
initiators
_links
_links
comment
string
  • readOnly: 1
igroup
igroup
proximity
proximity
node
name
string
uuid
string
lun
The LUN to which the initiator group is mapped.
name
string
The name of the LUN.
node
node
uuid
string
The unique identifier of the LUN.
lun_maps
A LUN map with which the initiator group is associated.
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
lun
lun
igroup_parent
comment
string
name
string
parent_igroups
uuid
string
portset
name
string
The name of the portset.
uuid
string
The unique identifier of the portset.
igroup
local_svm
boolean
Indicates whether the reported igroup is on the local SVM or the peer SVM. When deleting a replicated igroup, the local copy is deleted first and then the peer copy is deleted. If the error is encountered between these two operations and only the peer igroup remains, the peer igroup is reported and the problem might need to be corrected on the peer cluster.
name
string
uuid
string
summary
A user friendly message describing the error.
arguments
Message arguments
code
string
Error code
message
string
Error message
error
Information about asynchronous errors encountered while replicating this igroup. Igroups within a peering relationship are replicated in the same stream, so the error reported here might be related to this igroup or a prior replicated igroup that is now blocking the replication of this igroup. Both the error information and the igroup encountering the error are reported. If the error is configuration related, it can be corrected on the referenced igroup. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
igroup
igroup
peer_svm
The peered SVM to which the initiator group should be replicated. Optional in POST and PATCH. To clear any previously set replication peer, PATCH the replication.peer_svm object to null.
name
string
uuid
string
replication
error
error
peer_svm
peer_svm
state
string
The state of the replication queue associated with this igroup. If this igroup is not in the replication queue, the state is reported as ok. If this igroup is in the replication queue, but no errors have been encountered, the state is reported as replicating. If this igroup is in the replication queue and the queue is blocked by an error, the state is reported as error. When in the error state, additional context is provided by the replication.error property.
svm
name
string
uuid
string
target
firmware_revision
string
The firmware revision of the SCSI target specific to the OS type of the initiator group.
product_id
string
The product ID of the SCSI target.
vendor_id
string
The vendor ID of the SCSI target.
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host endpoints.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
comment
string
  • readOnly: 1
delete_on_unmap
boolean
lun_maps
array[lun_maps]
name
string
os_type
string
parent_igroups
portset
portset
replication
replication
supports_igroups
boolean
target
target
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
