Update an initiator group
Updates an initiator group to modify its properties as needed for managing access to LUNs in a SAN environment.
HTTP method and endpoint
PATCH /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
lun igroup modify -
lun igroup rename -
lun igroup bind -
lun igroup unbind
Learn more
uuid |
string |
path |
True |
The unique identifier of the initiator group. |
Request Body
| Name | Type | Description |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
connectivity_tracking |
An overview of the connections to ONTAP by the initiators in this group.
delete_on_unmap |
boolean |
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created. |
lun_maps |
array[lun_maps] |
All LUN maps with which the initiator is associated. If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved. There is an added computational cost to retrieving property values for |
name |
string |
The name of the initiator group. Required in POST; optional in PATCH. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH. |
parent_igroups |
array[igroup_parent] |
The initiator groups that contain this initiator group as as member. |
portset |
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset. Optional in POST and PATCH. PATCH |
supports_igroups |
boolean |
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The |
target |
Properties of the SCSI target to which the initiator group provides access. |
uuid |
string |
Example request
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"connection_state": "string",
"required_nodes": [
"name": "node1",
"lun_maps": [
"logical_unit_number": 0,
"lun": {
"name": "lun1",
"node": {
"name": "node1",
"name": "igroup1",
"os_type": "string",
"parent_igroups": [
"name": "igroup1",
"parent_igroups": [
null
"portset": {
"name": "portset1",
"target": {
"firmware_revision": "9111",
"product_id": "LUN C-Mode",
"vendor_id": "NETAPP"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254264 |
An attempt was made to bind a portset to an initiator group that is already bound to a portset. |
5373958 |
An invalid initiator group name was supplied for a rename operation. |
5374023 |
A rename operation failed because an initiator group with the same name already exists. |
5374027 |
An attempt was made to bind a portset with no member network interfaces to the initiator group. |
5374028 |
An attempt was made to bind a portset with an incompatible protocol to the initiator group. |
5374733 |
An initiator is already in another initiator group with a conflicting operating system type. |
5374745 |
An attempt was made to add an initiator group as a child to itself. |
5374746 |
The cluster is currently running in a mixed version and nested initiator groups cannot be created until the effective cluster version reaches 9.9.1. |
5374747 |
The cluster is currently running in a mixed version and initiator group comments cannot be created until the effective cluster version reaches 9.9.1. |
5374852 |
The initiator group does not exist. |
5374868 |
The initiator group was partially modified before an error was encountered while renaming the initiator group. |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state of the initiator group.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
alerts
summary |
A user friendly message describing the connection state of the initiator group. |
required_nodes
name |
string |
uuid |
string |
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
required_nodes |
array[required_nodes] |
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes. |
igroup_child
comment |
string |
A comment available for use by the administrator. |
igroups |
array[igroup_child] |
Further nested initiator groups. |
A link to the initiator with connectivity information relevant to its membership of this initiator group.
href |
string |
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
href |
string |
Overview of the initiator's connections to ONTAP.
connection_state |
string |
Connection state. |
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
name |
string |
The name of the initiator group. |
uuid |
string |
initiators
_links |
comment |
string |
igroup |
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group. |
node
name |
string |
uuid |
string |
lun
The LUN to which the initiator group is mapped.
name |
string |
The name of the LUN. |
node |
uuid |
string |
The unique identifier of the LUN. |
lun_maps
A LUN map with which the initiator group is associated.
logical_unit_number |
integer |
The logical unit number assigned to the LUN for initiators in the initiator group. |
lun |
The LUN to which the initiator group is mapped. |
igroup_parent
comment |
string |
name |
string |
parent_igroups |
uuid |
string |
portset
Optional in POST and PATCH. PATCH portset.name to an empty string ("") to unbind a portset from the initiator group.
name |
string |
The name of the portset. |
uuid |
string |
The unique identifier of the portset. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
target
firmware_revision |
string |
The firmware revision of the SCSI target specific to the OS type of the initiator group. |
product_id |
string |
The product ID of the SCSI target. |
vendor_id |
string |
The vendor ID of the SCSI target. |
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host initiators.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
comment |
string |
delete_on_unmap |
boolean |
lun_maps |
array[lun_maps] |
name |
string |
os_type |
string |
parent_igroups |
portset |
supports_igroups |
boolean |
target |
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
