REST API reference
Update an initiator group
Updates an initiator group to modify its configuration or properties as needed for managing access to LUNs.
HTTP method and endpoint
PATCH /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
  • lun igroup modify
  • lun igroup rename
  • lun igroup bind
  • lun igroup unbind
uuid
string
path
True
The unique identifier of the initiator group.
Request Body
Name Type Description
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
delete_on_unmap
boolean
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created.
lun_maps
array[lun_maps]
All LUN maps with which the initiator is associated.
If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved.
There is an added cost to retrieving property values for lun_maps. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
parent_igroups
array[igroup_parent]
The initiator groups that contain this initiator group as as member.
portset
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
Optional in POST and PATCH. PATCH portset.name to an empty string ("") to unbind a portset from the initiator group.
supports_igroups
boolean
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The initiators.name property cannot be used to determine this via a query because it reports initiators inherited from nested igroups.
uuid
string
Example request
  "comment": "string",
  "lun_maps": [
      "logical_unit_number": 0,
      "lun": {
        "name": "lun1",
        "node": {
          "name": "node1",
  "name": "igroup1",
  "os_type": "string",
  "parent_igroups": [
      "name": "igroup1",
  "portset": {
    "name": "portset1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254264
An attempt was made to bind a portset to an initiator group that is already bound to a portset.
5373958
An invalid initiator group name was supplied for a rename operation.
5374023
A rename operation failed because an initiator group with the same name already exists.
5374027
An attempt was made to bind a portset with no member network interfaces to the initiator group.
5374028
An attempt was made to bind a portset with an incompatible protocol to the initiator group.
5374733
An initiator is already in another initiator group with a conflicting operating system type.
5374745
An attempt was made to add an initiator group as a child to itself.
5374746
The cluster is currently running in a mixed version and nested initiator groups cannot be created until the effective cluster version reaches 9.9.1.
5374747
The cluster is currently running in a mixed version and initiator group comments cannot be created until the effective cluster version reaches 9.9.1.
5374852
The initiator group does not exist.
5374868
The initiator group was partially modified before an error was encountered while renaming the initiator group.
string
igroup_child
comment
string
igroups
array[]
Further nested initiator groups.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
name
string
uuid
string
initiators
comment
string
igroup
igroup
node
name
string
uuid
string
lun
The LUN to which the initiator group is mapped.
name
string
The name of the LUN.
node
node
uuid
string
The unique identifier of the LUN.
lun_maps
A LUN map with which the initiator group is associated.
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
lun
lun
igroup_parent
comment
string
name
string
parent_igroups
array[]
uuid
string
portset
name
string
The name of the portset.
uuid
string
The unique identifier of the portset.
svm
name
string
The name of the SVM.
uuid
string
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host initiators.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
comment
string
delete_on_unmap
boolean
lun_maps
array[lun_maps]
name
string
os_type
string
parent_igroups
portset
portset
supports_igroups
boolean
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
