Create an S3 bucket snapshot
POST /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
Introduced In: 9.16
Creates an S3 bucket snapshot.
Required properties
name- Name of the S3 bucket snapshot to be created.
Related ONTAP commands
vserver object-store-server bucket snapshot create
s3_bucket.uuid  |
string  |
path  |
True  |
Unique identifier of a bucket.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
bucket_uuid  |
string  |
The unique identifier of the bucket.  |
create_time  |
string  |
Creation time of the snapshot. It is the storage unit access time when the snapshot was created.  |
name  |
string  |
The name of the snapshot. Snapshot names must start with a lowercase letter, a number, or a hyphen, must end with a lowercase letter or a number, and cannot exceed 30 characters.  |
svm  |
Specifies the name of the SVM where this bucket exists.  |
uuid  |
string  |
The UUID of the snapshot in the bucket that uniquely identifies the snapshot in that bucket.  |
Example request
  "bucket_uuid": "2aec8270-58e3-11ef-861e-005056ae1130",
  "create_time": "2024-08-21 20:18:04 -0400",
  "name": "snap1",
  "svm": {
    "name": "svm1",
  "uuid": "522b29a1-3b26-11e9-bd58-0050568ea321"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error code | Message |
92405861  |
"The specified SVM UUID or bucket UUID does not exist.";  |
92406249  |
"Failed to create S3 bucket snapshot "{snapshot name}" for S3 bucket "{bucket name}" in SVM "{svm name}". Reason: {Reason for failure} ";  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
s3_bucket_snapshot
Information about an S3 bucket snapshot.
bucket_uuid  |
string  |
create_time  |
string  |
name  |
string  |
svm  |
uuid  |
string  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
