Create an S3 bucket snapshot
Creates an S3 bucket snapshot to preserve the current state of your bucket, which is useful for backup or recovery operations.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
Introduced in
ONTAP 9.16
Required properties
name- Name of the S3 bucket snapshot to be created.
Related ONTAP commands
vserver object-store-server bucket snapshot create
s3_bucket.uuid |
string |
path |
True |
Unique identifier of a bucket. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
bucket_uuid |
string |
The unique identifier of the bucket. |
create_time |
string |
Creation time of the snapshot. It is the storage unit access time when the snapshot was created. |
name |
string |
The name of the snapshot. Snapshot names must start with a lowercase letter, a number, or a hyphen, must end with a lowercase letter or a number, and cannot exceed 30 characters. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
The UUID of the snapshot in the bucket that uniquely identifies the snapshot in that bucket. |
Example request
"bucket_uuid": "2aec8270-58e3-11ef-861e-005056ae1130",
"create_time": "2024-08-21 20:18:04 -0400",
"name": "snap1",
"svm": {
"name": "svm1",
"uuid": "522b29a1-3b26-11e9-bd58-0050568ea321"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error code | Message |
92405861 |
"The specified SVM UUID or bucket UUID does not exist."; |
92406249 |
"Failed to create S3 bucket snapshot "{snapshot name}" for S3 bucket "{bucket name}" in SVM "{svm name}". Reason: {Reason for failure} "; |
href |
string |
_links
svm
name |
string |
uuid |
string |
s3_bucket_snapshot
Information about an S3 bucket snapshot.
bucket_uuid |
string |
create_time |
string |
name |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
