Create an external-role-mapping entry
Creates an entry for mapping external roles to ONTAP roles. Use this endpoint when you need to define role associations between external authentication providers and ONTAP.
HTTP method and endpoint
POST /security/external-role-mappings
Introduced in
ONTAP 9.16
Usage notes
Creates an external-role-mapping entry.
Required properties
external_role -
provider -
ontap_role
Optional properties
comment
Related ONTAP commands
security login external-role-mapping create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Any comment regarding this external-role-mapping entry. |
external_role |
string |
External Identity provider role. |
ontap_role |
ONTAP role to map with the external identity role.
provider |
string |
Type of the external identity provider. |
timestamp |
string |
Date and time indicating when this external-role-mapping entry was created. |
Example request
"comment": "string",
"external_role": "string",
"ontap_role": {
"name": "admin"
"provider": "string",
"timestamp": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
"records": [
"ontap_role": {
"name": "admin"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636243 |
Provided ONTAP role is not configured. |
href |
string |
self_link
_links
ontap_role
name |
string |
Role name |
security_external_role_mapping
comment |
string |
external_role |
string |
ontap_role |
provider |
string |
timestamp |
string |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
