REST API reference
Create an external-role-mapping entry
Creates an entry for mapping external roles to ONTAP roles. Use this endpoint when you need to define role associations between external authentication providers and ONTAP.
HTTP method and endpoint
POST /security/external-role-mappings
Introduced in
ONTAP 9.16
Usage notes
Creates an external-role-mapping entry.
Required properties
  • external_role
  • provider
  • ontap_role
Optional properties
  • comment
  • security login external-role-mapping create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Any comment regarding this external-role-mapping entry.
external_role
string
External Identity provider role.
ontap_role
ontap_role
ONTAP role to map with the external identity role.
  • Introduced in: 9.16
provider
string
Type of the external identity provider.
timestamp
string
Date and time indicating when this external-role-mapping entry was created.
Example request
  "comment": "string",
  "external_role": "string",
  "ontap_role": {
    "name": "admin"
  "provider": "string",
  "timestamp": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[security_external_role_mapping]
  "records": [
      "ontap_role": {
        "name": "admin"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5636243
Provided ONTAP role is not configured.
string
ontap_role
name
string
Role name
comment
string
external_role
string
ontap_role
ontap_role
provider
string
timestamp
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
