REST API reference
Create an external-role-mapping entry
POST /security/external-role-mappings
Introduced In: 9.16
Creates an external-role-mapping entry.
Required properties
  • external_role
  • provider
  • ontap_role
Optional properties
  • comment
  • security login external-role-mapping create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Any comment regarding this external-role-mapping entry.
external_role
string
External Identity provider role.
ontap_role
ontap_role
ONTAP role to map with the external identity role.
  • Introduced in: 9.16
provider
string
Type of the external identity provider.
timestamp
string
Date and time indicating when this external-role-mapping entry was created.
Example request
  "comment": "string",
  "external_role": "string",
  "ontap_role": {
    "name": "admin"
  "provider": "string",
  "timestamp": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[security_external_role_mapping]
  "records": [
      "ontap_role": {
        "name": "admin"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5636243
Provided ONTAP role is not configured.
string
ontap_role
name
string
Role name
comment
string
external_role
string
ontap_role
ontap_role
provider
string
timestamp
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
