Create a group-to-role mapping entry
POST /security/group/role-mappings
Introduced In: 9.16
Creates a group to role mapping entry.
Required properties
group_id -
ontap_role
Optional properties
comment
Related ONTAP commands
security login group role-mapping create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
comment  |
string  |
Any comment regarding this group entry.  |
group_id  |
integer  |
Group ID.  |
ontap_role  |
Role name.  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
Example request
  "comment": "string",
  "group_id": 1,
  "ontap_role": {
    "name": "admin"
  "scope": "string"
Status: 201, Created
num_records  |
integer  |
Number of records.  |
records  |
array[group_role_mappings]  |
  "records": [
      "group_id": 1,
      "ontap_role": {
        "name": "admin"
      "scope": "string"
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636242  |
The configured group ID does not exist in the group configuration.  |
5636243  |
The configured role name does not exist in the SVM where the group ID is configured.  |
href  |
string  |
_links
ontap_role
Role name.
name  |
string  |
Role name  |
group_role_mappings
comment  |
string  |
group_id  |
integer  |
Group ID.  |
ontap_role  |
Role name.  |
scope  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
