Create a group-to-role mapping entry
Creates a mapping entry between a group and a role, defining access permissions for the specified group. This is useful for organizing and managing group access within your system.
HTTP method and endpoint
POST /security/group/role-mappings
Introduced in
ONTAP 9.16
Usage notes
Creates a group to role mapping entry.
Required properties
group_id -
ontap_role
Optional properties
comment
Related ONTAP commands
security login group role-mapping create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Any comment regarding this group entry. |
group_id |
integer |
Group ID. |
ontap_role |
Role name. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"comment": "string",
"group_id": 1,
"ontap_role": {
"name": "admin"
"scope": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[group_role_mappings] |
"records": [
"group_id": 1,
"ontap_role": {
"name": "admin"
"scope": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636242 |
The configured group ID does not exist in the group configuration. |
5636243 |
The configured role name does not exist in the SVM where the group ID is configured. |
href |
string |
_links
ontap_role
Role name.
name |
string |
Role name |
group_role_mappings
comment |
string |
group_id |
integer |
Group ID. |
ontap_role |
Role name. |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
