REST API reference
Create a group-to-role mapping entry
Creates a mapping entry between a group and a role, defining access permissions for the specified group. This is useful for organizing and managing group access within your system.
HTTP method and endpoint
POST /security/group/role-mappings
Introduced in
ONTAP 9.16
Usage notes
Creates a group to role mapping entry.
Required properties
  • group_id
  • ontap_role
Optional properties
  • comment
  • security login group role-mapping create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Any comment regarding this group entry.
group_id
integer
Group ID.
ontap_role
ontap_role
Role name.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "comment": "string",
  "group_id": 1,
  "ontap_role": {
    "name": "admin"
  "scope": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[group_role_mappings]
  "records": [
      "group_id": 1,
      "ontap_role": {
        "name": "admin"
      "scope": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5636242
The configured group ID does not exist in the group configuration.
5636243
The configured role name does not exist in the SVM where the group ID is configured.
string
ontap_role
Role name.
name
string
Role name
group_role_mappings
comment
string
group_id
integer
Group ID.
ontap_role
ontap_role
Role name.
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
