REST API reference
Create a group entry
POST /security/groups
Introduced In: 9.16
Creates a group entry.
Required properties
  • name
Optional properties
  • owner
  • type
  • uuid
  • comment
  • security login group create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Any comment regarding this group entry.
create_time
string
Date and time indicating when this group entry was created.
id
integer
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number.
name
string
Group name.
owner
owner
Group owner. Used to identify a cluster or an SVM.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
type
string
Group type.
uuid
string
Group UUID from external Active Directory.
Example request
  "comment": "Azure Group",
  "create_time": "string",
  "id": 0,
  "name": "AzureGroup1",
  "owner": {
    "name": "svm1",
  "scope": "string",
  "type": "entra",
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[security_group]
  "num_records": 1,
  "records": [
      "id": 0,
      "owner": {
        "name": "svm1",
      "scope": "string",
      "type": "entra",
      "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5636231
Failed to create the group because the maximum number of allowed group IDs has been reached.
5636232
The group name does not satisfy the length requirement.
5636235
Duplicate UUID.
5636244
Failed to delete the group because it is part of the group role mapping configuration.
string
owner
name
string
uuid
string
security_group
comment
string
create_time
string
id
integer
name
string
Group name.
owner
owner
scope
string
type
string
Group type.
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
