Create a group entry
Creates a group entry to manage access and permissions within your ONTAP environment. Use this endpoint when you need to define a new group with specific properties such as name, owner, type, and additional comments.
HTTP method and endpoint
POST /security/groups
Introduced in
ONTAP 9.16
Required properties
name
Optional properties
owner -
type -
uuid -
comment
Related ONTAP commands
security login group create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Any comment regarding this group entry. |
create_time |
string |
Date and time indicating when this group entry was created. |
id |
integer |
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number. |
name |
string |
Group name. |
owner |
Group owner. Used to identify a cluster or an SVM. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
type |
string |
Group type. |
uuid |
string |
Group UUID from external Active Directory. |
Example request
"comment": "Azure Group",
"create_time": "string",
"id": 0,
"name": "AzureGroup1",
"owner": {
"name": "svm1",
"scope": "string",
"type": "entra",
"uuid": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[security_group] |
"num_records": 1,
"records": [
"id": 0,
"owner": {
"name": "svm1",
"scope": "string",
"type": "entra",
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636231 |
Failed to create the group because the maximum number of allowed group IDs has been reached. |
5636232 |
The group name does not satisfy the length requirement. |
5636235 |
Duplicate UUID. |
5636244 |
Failed to delete the group because it is part of the group role mapping configuration. |
href |
string |
self_link
_links
owner
name |
string |
uuid |
string |
security_group
comment |
string |
create_time |
string |
id |
integer |
name |
string |
Group name. |
owner |
scope |
string |
type |
string |
Group type. |
uuid |
string |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
