The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Protocols NFS tls interfaces endpoint overview
Retrieving the NFS over TLS interface configuration details
# The API:
GET /api/protocols/nfs/tls/interfaces
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/tls/interfaces"
Updating the NFS over TLS interface configuration
# The API:
PATCH /api/protocols/nfs/tls/interfaces/{interface.uuid}
# The call:
curl -d "@test_patch_nfs_tls_interface.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/tls/interfaces/e62936de-7342-11e8-9eb4-0050568be2b7"
test_patch_nfs_tls_interface.txt(body):
 "enabled" : "true"
