Manage NFS over TLS interface configuration details
Manage NFS over TLS interface configuration details to secure data transmission between your ONTAP cluster and connected clients. Use these endpoints to retrieve and update the configuration settings for NFS interfaces using TLS.
Retrieving the NFS over TLS interface configuration details
# The API: GET /api/protocols/nfs/tls/interfaces # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/tls/interfaces"
Updating the NFS over TLS interface configuration
# The API:
PATCH /api/protocols/nfs/tls/interfaces/{interface.uuid}
# The call:
curl -d "@test_patch_nfs_tls_interface.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/tls/interfaces/e62936de-7342-11e8-9eb4-0050568be2b7"
test_patch_nfs_tls_interface.txt(body):
"enabled" : "true"
