REST API reference
Delete a VLAN or LAG
Deletes a VLAN or LAG when you no longer need the associated network configuration, ensuring efficient management of network resources.
HTTP method and endpoint
DELETE /network/ethernet/ports/{uuid}
Introduced in
ONTAP 9.6
  • network port ifgrp delete
  • network port vlan delete
uuid
string
path
True
Port UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
1376858
Port already has an interface bound.
1966189
Port is the home port or current port of an interface.
1966302
This interface group is hosting VLAN interfaces that must be deleted before running this command.
1967105
Cannot delete a physical port.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
