Delete a VLAN or LAG
Deletes a VLAN or LAG when you no longer need the associated network configuration, ensuring efficient management of network resources.
HTTP method and endpoint
DELETE /network/ethernet/ports/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network port ifgrp delete -
network port vlan delete
uuid |
string |
path |
True |
Port UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376858 |
Port already has an interface bound. |
1966189 |
Port is the home port or current port of an interface. |
1966302 |
This interface group is hosting VLAN interfaces that must be deleted before running this command. |
1967105 |
Cannot delete a physical port. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
