REST API reference
Delete a VLAN or LAG
Deletes a VLAN or LAG to remove network configurations that are no longer needed or to reconfigure your network setup.
HTTP method and endpoint
DELETE /network/ethernet/ports/{uuid}
Introduced in
ONTAP 9.6
  • network port ifgrp delete
  • network port vlan delete
uuid
string
path
True
Port UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1376858
Port already has an interface bound.
1966189
Port is the home port or current port of an interface.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
