REST API reference
Delete the FPolicy configuration for an SVM
Deletes an FPolicy configuration for a specific SVM. This action is typically used to remove unwanted or outdated configurations associated with FPolicy for a given storage virtual machine.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the FPolicy configuration for the specified SVM. Before deleting the FPolicy configuration, ensure that all policies belonging to the SVM are disabled.
Important notes: The volume associated with the FPolicy Persistent Store is not automatically deleted from the FPolicy general endpoint. The associated volume can be removed manually.
  • fpolicy delete
  • fpolicy policy scope delete
  • fpolicy policy delete
  • fpolicy policy event delete
  • fpolicy policy external-engine delete
  • fpolicy persistent-store delete
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9765031
If any of the FPolicy engine, FPolicy event or FPolicy policy deletion fails due to a systemic error or hardware failure, the cause of the failure is detailed in the error message.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
