Delete the FPolicy configuration for an SVM
Deletes the FPolicy configuration for a specified SVM to manage or remove associated policies effectively.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Before deleting the FPolicy configuration, ensure that all policies belonging to the SVM are disabled.
Related ONTAP commands
fpolicy delete -
fpolicy policy scope delete -
fpolicy policy delete -
fpolicy policy event delete -
fpolicy policy external-engine delete -
fpolicy persistent-store delete
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9765031 |
If any of the FPolicy engine, FPolicy event or FPolicy policy deletion fails due to a systemic error or hardware failure, the cause of the failure is detailed in the error message. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
