Delete the FPolicy configuration for an SVM
Removes the FPolicy configuration for a specified SVM. Use this when you need to clean up or reconfigure FPolicy settings.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the FPolicy configuration for the specified SVM. Before deleting the FPolicy configuration, ensure that all policies belonging to the SVM are disabled.
Related ONTAP commands
fpolicy delete -
fpolicy policy scope delete -
fpolicy policy delete -
fpolicy policy event delete -
fpolicy policy external-engine delete
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9765030 |
Cannot delete an FPolicy configuration if any of the policy is enabled |
9765031 |
If any of the FPolicy engine, FPolicy event or FPolicy policy deletion fails due to a systemic error or hardware failure, the cause of the failure is detailed in the error message. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
