Delete the FPolicy configuration for an SVM
DELETE /protocols/fpolicy/{svm.uuid}
Introduced In: 9.6
Deletes the FPolicy configuration for the specified SVM. Before deleting the FPolicy configuration, ensure that all policies belonging to the SVM are disabled.
Related ONTAP commands
fpolicy delete -
fpolicy policy scope delete -
fpolicy policy delete -
fpolicy policy event delete -
fpolicy policy external-engine delete
Learn more
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9765030  |
Cannot delete an FPolicy configuration if any of the policy is enabled  |
9765031  |
If any of the FPolicy engine, FPolicy event or FPolicy policy deletion fails due to a systemic error or hardware failure, the cause of the failure is detailed in the error message.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
