REST API reference
Retrieve a snapshot for a specific application component
Retrieves a single snapshot of an application component to access its granular data. This is particularly useful for Maxdata template applications, where you need to focus on one part of the application for detailed analysis or recovery.
HTTP method and endpoint
GET /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieve a snapshot of an application component.
This endpoint is only supported for Maxdata template applications.
Component snapshots are essentially more granular application snapshots. There is no difference beyond the scope of the operation.
application.uuid
string
path
True
Application UUID
component.uuid
string
path
True
Application Component UUID
uuid
string
path
True
Snapshot UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
application
application
comment
string
Comment. Valid in POST
component
component
consistency_type
string
Consistency Type. This is for categorization only. A snapshot should not be set to application consistent unless the host application is quiesced for the snapshot. Valid in POST
create_time
string
Creation Time
is_partial
boolean
A partial snapshot means that not all volumes in an application component were included in the snapshot.
name
string
Snapshot name. Valid in POST
svm
svm
uuid
string
Snapshot UUID. Valid in URL
      "href": "/api/resourcelink"
  "application": {
    "name": "string",
    "uuid": "string"
  "comment": "string",
  "component": {
    "name": "string",
    "uuid": "string"
  "consistency_type": "string",
  "create_time": "string",
  "name": "string",
  "svm": {
    "name": "string",
    "uuid": "string"
  "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
application
_links
_links
name
string
Application Name
uuid
string
Application UUID. Valid in URL
component
_links
_links
name
string
Component Name
uuid
string
Component UUID
svm
name
string
SVM Name
uuid
string
SVM UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
