Retrieve a Snapshot copy for a specific application component
GET /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}
Introduced In: 9.6
Retrieve a Snapshot copy of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
uuid |
string |
path |
True |
Snapshot UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
application |
comment |
string |
Comment. Valid in POST |
component |
consistency_type |
string |
Consistency Type. This is for categorization only. A Snapshot copy should not be set to application consistent unless the host application is quiesced for the Snapshot copy. Valid in POST |
create_time |
string |
Creation Time |
is_partial |
boolean |
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy. |
name |
string |
Snapshot copy name. Valid in POST |
svm |
uuid |
string |
Snapshot copy UUID. Valid in URL |
"href": "/api/resourcelink"
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"component": {
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
application
_links |
name |
string |
Application Name |
uuid |
string |
Application UUID. Valid in URL |
component
_links |
name |
string |
Component Name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM Name |
uuid |
string |
SVM UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
