Retrieve a snapshot for a specific application component
GET /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}
Introduced In: 9.6
Retrieve a snapshot of an application component.
This endpoint is only supported for Maxdata template applications.
Component snapshots are essentially more granular application snapshots. There is no difference beyond the scope of the operation.
Learn more
application.uuid  |
string  |
path  |
True  |
Application UUID  |
component.uuid  |
string  |
path  |
True  |
Application Component UUID  |
uuid  |
string  |
path  |
True  |
Snapshot UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
application  |
comment  |
string  |
Comment. Valid in POST  |
component  |
consistency_type  |
string  |
Consistency Type. This is for categorization only. A snapshot should not be set to application consistent unless the host application is quiesced for the snapshot. Valid in POST  |
create_time  |
string  |
Creation Time  |
is_partial  |
boolean  |
A partial snapshot means that not all volumes in an application component were included in the snapshot.  |
name  |
string  |
Snapshot name. Valid in POST  |
svm  |
uuid  |
string  |
Snapshot UUID. Valid in URL  |
      "href": "/api/resourcelink"
  "application": {
    "name": "string",
    "uuid": "string"
  "comment": "string",
  "component": {
    "name": "string",
    "uuid": "string"
  "consistency_type": "string",
  "create_time": "string",
  "name": "string",
  "svm": {
    "name": "string",
    "uuid": "string"
  "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
application
_links  |
name  |
string  |
Application Name  |
uuid  |
string  |
Application UUID. Valid in URL  |
component
_links  |
name  |
string  |
Component Name  |
uuid  |
string  |
Component UUID  |
svm
name  |
string  |
SVM Name  |
uuid  |
string  |
SVM UUID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
