Retrieve observed events
Retrieves a collection of observed events, which helps you monitor and analyze occurrences within your environment. Use this to filter and understand event severities, with the option to include 'DEBUG' events when needed.
HTTP method and endpoint
GET /support/ems/events
Introduced in
ONTAP 9.6
Usage notes
The default behavior is to filter 'DEBUG' severity events. If those events are required, a severity query must be provided. |
Related ONTAP commands
event log show
time |
string |
query |
False |
Filter by time |
message.name |
string |
query |
False |
Filter by message.name |
message.severity |
string |
query |
False |
Filter by message.severity |
source |
string |
query |
False |
Filter by source |
log_message |
string |
query |
False |
Filter by log_message |
parameters.name |
string |
query |
False |
Filter by parameters.name |
parameters.value |
string |
query |
False |
Filter by parameters.value |
index |
integer |
query |
False |
Filter by index |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
filter.name |
string |
query |
False |
Filter the collection returned using an event filter
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"index": 1,
"log_message": "string",
"message": {
"name": "callhome.spares.low",
"severity": "emergency"
"node": {
"name": "node1",
"parameters": [
"name": "numOps",
"value": 123
"source": "string",
"time": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983093 |
The provided filter is unknown. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self
href |
string |
_links
self |
_links
self |
message
_links |
name |
string |
Message name of the event. Returned by default. |
severity |
string |
Severity of the event. Returned by default. |
node
_links |
name |
string |
uuid |
string |
parameters
name |
string |
Name of parameter |
value |
string |
Value of parameter |
records
_links |
index |
integer |
Index of the event. Returned by default. |
log_message |
string |
A formatted text string populated with parameter details. Returned by default. |
message |
node |
parameters |
array[parameters] |
A list of parameters provided with the EMS event. |
source |
string |
Source |
time |
string |
Timestamp of the event. Returned by default. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
