REST API reference
Retrieve observed events
Accesses a collection of observed events, which helps in monitoring and managing your system's event logs.
HTTP method and endpoint
GET /support/ems/events
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of observed events.
  • event log show
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
message.severity
string
query
False
Filter by message.severity
message.name
string
query
False
Filter by message.name
time
string
query
False
Filter by time
log_message
string
query
False
Filter by log_message
index
integer
query
False
Filter by index
parameters.name
string
query
False
Filter by parameters.name
parameters.value
string
query
False
Filter by parameters.value
source
string
query
False
Filter by source
filter.name
string
query
False
Filter the collection returned using an event filter
  • Introduced in: 9.8
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": "3",
  "records": [
      "index": "1",
      "log_message": "string",
      "message": {
        "name": "callhome.spares.low",
        "severity": "emergency"
      "node": {
        "name": "node1",
      "parameters": [
          "name": "numOps",
          "value": "123"
      "source": "string",
      "time": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
message
_links
_links
name
string
Message name of the event. Returned by default.
severity
string
Severity of the event. Returned by default.
node
_links
_links
name
string
uuid
string
parameters
name
string
Name of parameter
value
string
Value of parameter
records
_links
_links
index
integer
Index of the event. Returned by default.
log_message
string
A formatted text string populated with parameter details. Returned by default.
message
message
node
node
parameters
array[parameters]
A list of parameters provided with the EMS event.
source
string
Source
time
string
Timestamp of the event. Returned by default.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
