REST API reference
Retrieve observed events
Retrieves a list of observed events, helping you monitor and analyze the system's activities and occurrences. This can assist in troubleshooting or ensuring system health by reviewing logged events.
HTTP method and endpoint
GET /support/ems/events
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of observed events.
  • event log show
stateful
boolean
query
False
Filter by stateful
  • Introduced in: 9.11
uuid
string
query
False
Filter by uuid
action.possible_actions.action
string
query
False
Filter by action.possible_actions.action
action.possible_actions.parameters.format
string
query
False
Filter by action.possible_actions.parameters.format
action.possible_actions.parameters.name
string
query
False
Filter by action.possible_actions.parameters.name
action.possible_actions.parameters.type
string
query
False
Filter by action.possible_actions.parameters.type
action.possible_actions.invoke.verb
string
query
False
Filter by action.possible_actions.invoke.verb
message.name
string
query
False
Filter by message.name
message.severity
string
query
False
Filter by message.severity
time
string
query
False
Filter by time
source
string
query
False
Filter by source
creation_time
string
query
False
Filter by creation_time
log_message
string
query
False
Filter by log_message
state
string
query
False
Filter by state
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
parameters.name
string
query
False
Filter by parameters.name
parameters.value
string
query
False
Filter by parameters.value
index
integer
query
False
Filter by index
last_update_time
string
query
False
Filter by last_update_time
filter.name
string
query
False
Filter the collection returned using an event filter
  • Introduced in: 9.8
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 3,
  "records": [
      "action": {
        "possible_actions": [
            "action": "scheduled",
            "invoke": {
              "verb": "patch"
            "parameters": [
                "format": "date-time",
                "name": "schedule-at",
                "type": "string"
      "creation_time": "string",
      "index": 1,
      "last_update_time": "string",
      "log_message": "string",
      "message": {
        "name": "callhome.spares.low",
        "severity": "emergency"
      "node": {
        "name": "node1",
      "parameters": [
          "name": "numOps",
          "value": "123"
      "source": "string",
      "state": "auto_healing",
      "time": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
invoke
Opaque URL and HTTP verb used to perform the action.
_links
verb
string
parameters
format
string
Indicates the contents and format of the string.
name
string
Parameter name.
type
string
Parameter type.
possible_actions
action
string
Name of the action.
invoke
invoke
parameters
array[parameters]
Parameter list for the action.
action
Actions that can be performed on the alert. To perform an action, send a POST request to the "invoke" URL with appropriate set of parameter values from the "possible_actions" list.
possible_actions
array[possible_actions]
A list of possible actions along with the parameter names and types that can be used with the opaque URL.
message
_links
_links
name
string
Message name of the event. Returned by default.
severity
string
Severity of the event. Returned by default.
node
_links
_links
name
string
uuid
string
parameters
name
string
Name of parameter
value
string
Value of parameter
records
_links
_links
action
action
creation_time
string
Timestamp of the event creation.
index
integer
Index of the event. Returned by default.
last_update_time
string
Timestamp of the last update to the alert.
log_message
string
A formatted text string populated with parameter details. Returned by default.
message
message
node
node
parameters
array[parameters]
A list of parameters provided with the EMS event.
source
string
Source
state
string
Indicates the event state. A stateful event tracks the state changes of a system condition and reflects the current system condition.
stateful
boolean
Indicates whether the event is stateful. A stateful event tracks the state changes of a system condition and reflects the current system condition while a stateless event simply reports a certain system condition that has occurred sometime in the past.
time
string
Timestamp of the event. Returned by default.
uuid
string
The UUID that uniquely identifies the alert.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
